SN-HC-SR04 Ultrasonic Ranging Module
Postby darkconvoy » Tue Oct 08, 2013 6:36 pm
Is it possible to use this sensor by putting it an an angle to detect an object or surface? Or do I need a different sensor?
darkconvoy
Re: SN-HC-SR04 Ultrasonic Ranging Module
Postby robosang » Wed Oct 09, 2013 10:14 am
Why don try it?
Postby sich » Thu Oct 10, 2013 12:02 pm
Your system needs to consider whether the object's surface is perpendicular to sensing direction, especially when the surface is flat and smooth. Different sensor has different directional characteristics. It should be stated in the datasheet.
Postby darkconvoy » Sun Oct 13, 2013 6:18 pm
I tried it and when I pointed the sensor at the floor (tiled) at an angle, it does not show any reading but when I put an obstacle in front of it, the sensor can detect it. Any reason or suggestions?
darkconvoy
Postby ober » Wed Oct 16, 2013 9:32 am
That is nature of ultrasonic or infrared sensor. It require reflection from obstacle/object, and there are using wave (sound wave for ultrasonic and light wave for infrared). Wave have reflection angle that we learn in physic. Search for wave reflection and you should understand it. Here is one link: http://www.physicsclassroom.com/class/waves/u10l3b.cfm
Postby darkconvoy » Wed Oct 16, 2013 1:28 pm
Do you have any suggestion on what I should do? Change the sensor type or do something else to improve the reading?
darkconvoy
Postby yonghui » Wed Oct 16, 2013 4:54 pm
rotate the ultrasound sensor with a servo to detect in all angle
Postby darkconvoy » Thu Oct 17, 2013 11:37 pm
I want to use the sensor to detect objects/holes at the floor. Any suggestion?
darkconvoy
Postby yonghui » Fri Oct 18, 2013 10:37 am
why dont use camera, write algorithm for object detection.
Postby darkconvoy » Sun Oct 20, 2013 1:02 am
Can't I use an ultrasonic or infrared to do so?
darkconvoy
Users browsing this forum: No registered users and 33 guests
