humidity and temperature sensor combine source code
Postby alung92 » Tue Aug 26, 2014 12:40 am
i had Temperature Sensor Module and Humidity Sensor Module both bought from cytron and connect to arduino main board. i tried combine this 2 sensor source code together. I expected will display temperature reading and humidity reading in RH% , but the output is quite weird. MAybe my source code, formula or somewhere got mistake. Someone please help me to correct it . i Need help !!!!. thanks a lot .
float val = 0;
float RH = 0;
float temp;
  val = analogRead(0);
  delay(500);
  Serial.println(val);
  //RH = ((((val/1023)*5)-0.8)/3.1)*100;
  Serial.println(RH);
  RH = ((0,0004*20 + 0,149)*temp)-(0,0617*20 + 24,436);
  delay(500);
temp = analogRead(3)/9.31;
Serial.print("TEMPRATURE = ");
Serial.print(temp);
Serial.print("*C");
Serial.println();
delay(1000);
output
TEMPRATURE = 30.50*C
24.00
4109.22
23.00
4109.22
TEMPRATURE = 30.61*C
24.00
4109.22
24.00
4125.22
24.00
4125.22
24.00
4125.22
24.00
4109.22
alung92
Re: humidity and temperature sensor combine source code
Postby yonghui » Tue Aug 26, 2014 2:42 pm
I am quite confused with your code.
i see you use value that is not properly initialize to the reading of adc.
Postby alung92 » Tue Aug 26, 2014 3:02 pm
I'm quite new in this field ,i'm trying and some code copy from other web page . Can u give me a example and guide line how to write code with this two sensor combine together. Thanks a lot .
alung92
Postby yonghui » Tue Aug 26, 2014 9:35 pm
i assume that Humidity sensor is connected AN0 and Temperature sensor is connected to AN3
word Temperature;
word Humidity;
Humidity = analogRead(0);
Temperature =analogRead(3);
// do some calculation here to convert the humidity value to valid value then print it
// print Humidity
// print temperature
delay(500);
