50 Amp Current Sensor
Postby pradeep20 » Tue Feb 10, 2015 3:34 am
Hey,
I wish to connect the BB-ACS756 sensor with a Solar Panel.
From the referencing provided, connection to motor is only shown.
Is there a way to connect the sensor with a solar panel of suitable rating?
Thank you. :D :D
pradeep20
Re: 50 Amp Current Sensor
Postby ober » Tue Feb 10, 2015 9:24 am
Is the same as motor, current is measure in series.
Postby pradeep20 » Sat Feb 14, 2015 4:32 pm
Thank you for your reply.
My confusion is that, motor receives current from the battery.
But in the case of the panel, both the solar panel and batteries gives output power.
And i only wish to know the current given out by the solar panel and not the batteries.
Thank you.
pradeep20
Postby ober » Sun Feb 15, 2015 10:45 am
You are confused 8-)
OK, take out the current sensor, how will the setup look like, take a photo and I might be able to show you where to connect it.
Postby pradeep20 » Sun Feb 15, 2015 6:02 pm
Thanks for your reply.
Attached is a picture of the circuit drawing.
The square marked in black is the area where im guessing it goes but i need confirmation.
Thank you.
pradeep20
Postby ober » Mon Feb 16, 2015 10:04 am
Yes, you are right, that is correct place.
Postby pradeep20 » Mon Feb 16, 2015 1:46 pm
Thank you very much for your help.
Appreciate it. :)
pradeep20
