IR sensor
IR sensor
Postby zhui » Thu Apr 23, 2015 10:18 pm
I am looking into a type of IR sensor which can sense in few mm.
Can i know which one is suitable for me?
PIR sensor Module/IR Sensor Set With Socket/IR Sensor Set
btw i want the result in analog form.
zhui
Re: IR sensor
Postby ober » Sat Apr 25, 2015 10:26 pm
few mm? That is quite small for IR sensor. IR sensor depends a lot of the reflection of Infrared; angle of object, color of object, surface of object, will affect the reflection.
PIR will not give you distance and even object, it senses Passive Infrared, read more here: http://en.wikipedia.org/wiki/Passive_infrared_sensor
mm in resolution, maybe you could check out the high resolution ultrasonic sensor.
