Fingerprint Scanner SM630A Interface with vb2010
Postby hanpin123 » Mon May 16, 2016 10:18 am
Hi all, recently i bought a sm630a. And i already done writing my coding in vb2010. but when i send command to sm630, and that component did not response to my vb2010, not even send error response. is it because there were no link in between my vb and that scanner? :( hope it could be solve as fast as possible. thanks you
hanpin123
Re: Fingerprint Scanner SM630A Interface with vb2010
Postby bengchet » Mon May 16, 2016 2:42 pm
You can try this tutorial to test your fingerprint scanner. If it works as expected, then the problem comes from your coding in vb2010. You will need to check if your application is properly connected to your fingerprint scanner or sending correct data to fingerprint scanner.
