PIR sensor for school project.
Postby raymondfoo » Thu Jul 14, 2016 1:58 pm
Hi guys, I am doing a school project which need to have transistors or diodes. So I want to design a simple circuit using PIR sensor module that can be found in cytron technologies website. Here is the link to the circuit I found: http://www.circuitsgallery.com/2015/12/ ... ystem.html
This circuit is simple, what I want to ask is: is the pir sensor module in the circuit is similar to the one in cytron website? Can this circuit works?
raymondfoo
Re: PIR sensor for school project.
Postby ZaM » Thu Jul 14, 2016 3:12 pm
Yes, its compatible model. We also have other component.
PIR Sensor: http://www.cytron.com.my/p-sn-pir
Resistor 1K Ohm: http://www.cytron.com.my/p-rs-025w-1k
Buzzer: http://www.cytron.com.my/p-so-buzz
Transistor BC548: http://www.cytron.com.my/p-tr-bc-548
ZaM
Postby raymondfoo » Thu Jul 14, 2016 3:49 pm
ZaM WROTE:Yes, its compatible model. We also have other component.
Hah, nice! Thanks. One more question, how do I connect the buzzer to breadboard? As well as PIR sensor. What do I need?
raymondfoo
Postby ZaM » Fri Jul 15, 2016 11:06 am
Hi, for PIR sensor, you can use this product. But for Buzzer, need soldering station to solder this, or if you dont have any tool, you can choose to use one of this wire, terminal block top and terminal block side.
ZaM
