LDR sensor for school project.
Postby raymondfoo » Sun Jul 17, 2016 11:30 am
Can this circuit works?
http://www.buildcircuit.com/wp-content/ ... 00x263.jpg
Is the LDR compatible with the cytron's LDR? And which LED should I use? And about R3, it mentioned 1k-4.7k, that means it is variable resistor? Which component is it?
raymondfoo
Re: LDR sensor for school project.
Postby Idris » Mon Jul 18, 2016 10:37 am
Hi raymondfoo,
raymondfoo WROTE:Can this circuit works?
To know whether the circuit is working or not, you need to try it first. :)
raymondfoo WROTE:Is the LDR compatible with the cytron's LDR?
Yes it is compatible.
raymondfoo WROTE:And which LED should I use?
You can use any normal LED: Green LED, Red LED or Yellow LED.
raymondfoo WROTE:And about R3, it mentioned 1k-4.7k, that means it is variable resistor? Which component is it?
It can be fix (any value from 1k to 4.7k) or variable. This resistance will effect the LDR sensitivity.
