Cytron Technical Forum
http://forum.cytron.io/
M18 Capacitive Proximity Sensor
http://forum.cytron.io/viewtopic.php?f=9&t=13050
Page
1
of
1
Thu Apr 12, 2018 1:37 pm
by
Priyanshi
Hey, is the sensor compatible with arduino? Some said that an external circuit may be needed to connect it with arduino. Can you help me with the circuit and also with it's code with arduino?
Re: M18 Capacitive Proximity Sensor
Mon Apr 16, 2018 11:33 am
by
Hi Priyanshi,
Yes it is compatible with Arduino You can refer to the
Wiring Diagram
Operating voltage: DC10-30V
Output signal: NPN, digital
Since Arduino IO pins is 5V, you can make connection something like this.
Then read digital signal at pin 9.
Hope this helps. Thanks.
