Make Raspberry Pi Zero run non - stop
Postby dayanamahfuz » Tue May 07, 2019 10:26 am
Last month our company has purchase a couple of product from your website such as: Raspberry Pi Zero, Maker pHAT, jumper wires and sensor PIR,
we develop a Home Detection System for office security used based on your coding and youtube video.
i also used crontab to let the coding run after reboot. The system work perfectly for the entire office hour.
however, every morning i discover that the device in sleep mode and did not detect any movement system or give a notification through telegram. company wifi is always available 24h. any help or suggestion will be helpful. tq in advance
dayanamahfuz
Re: Make Raspberry Pi Zero run non - stop
Postby Idris » Fri May 10, 2019 9:54 am
Hi dayanamahfuz,
I have develop IoT wall clock at my home and run for weeks/months. The problem only occur when black out or Unifi down. However, when the power is up, it will run another weeks/months.
Maybe the 1st action you can try is to put indicator like LED blinking or LCD display to indicate the script is continuously running.
Hope this helps.
