Making a room temperature control with Raspberry Pi 2
Postby kamion » Tue Jun 30, 2020 4:09 pm
Hello,
Here's the problem I'm trying to solve.
1) The main objective is to save electricity, and I don't want to leave the aircond on all night.
2) If I the put Aircond on timer, it will turn off, but I have to wake up to turn on the fan.
3) Even with fan on, some times it gets hot and humid again after a couple hours, and I have to get up and switch off fan and turn on aircond.
4) Aircond and ceiling fan both have IR control.
I want to automate the room climate control with Raspberry Pi, sensing temperature and humidity in the room and to control the aircond and fan as appropriate.
I'm looking at:
i) some sort of temperature and humidity sensor, either:
a) https://my.cytron.io/p-grove-temperatur ... nsor-dht11
b) https://my.cytron.io/p-esp01-humidity-a ... ure-module
which of the above is easier to wire up to the Pi on a breadboard?
ii) IR receiver: to read in the IR signal from current aircond and fan controller, so I can transmit it later
iii) IR transmitter: to control both the fan and aircond
I found the following, will it work for ii) and iii) above?
https://my.cytron.io/p-ir-sensor-set-with-socket
or do I need the following for ii)?
https://my.cytron.io/p-ir-receiver-diode-vs1838b-38khz
and some other IR transmitter?
kamion
