DTH11 temperature and humidity sensor
Postby input54 » Wed Nov 30, 2022 11:23 pm
I have the Maker pi Pico board and I connect the Grove sensor DTH11 on Grove port 1 and I use the following code:
 import dht
import machine
import utime
pin = machine.Pin(1)
data_dht = dht.DHT11(pin)
while True:
    utime.sleep(2)
    data_dht.measure()
    print()
    print ( f" temperature (C) :{data_dht.temperature()}")
    print ( f" humidity (%): {data_dht.humidity()} ")
But I receive this error:
Traceback (most recent call last):
File "<stdin>", line 11, in <module>
File "dht.py", line 25, in measure
OSError: [Errno 110] ETIMEDOUT
Does someone have a solution for this
input54
Re: DTH11 temperature and humidity sensor
Postby input54 » Fri Dec 02, 2022 5:54 pm
I found out that the Grovesensor needs a library to work, so there is no library for Micropython.
For example, does anyone know what kind of sensors you can use the Grove ports with.
input54
Users browsing this forum: No registered users and 47 guests
