dear cytron.......
dear cytron.......
Postby phycoman » Tue Oct 06, 2009 2:40 pm
hello.........
i want 2 ask u bout flexiforce and encoder with plate.............
how 2 operate this 2 sensor.........
also can i integrated with the PCI7432 card.........
and how to operate with this sensor........
phycoman
Re: dear cytron.......
Postby robosang » Tue Oct 06, 2009 5:32 pm
I am not Cytron staff, but I used the flexiforce before. And Yet, I think you should go through the data sheet before using a sensor or any product to ensure you are getting the thing that you need. Flexiforce is just simply a sensor that can change the pressing force on the end that sensor into resistance. Simple way to measure it is to apply voltage across the terminal and it will become a voltage divider.
Never use the encoder with plate before, but if I am not mistaken, again I think they should have the User's Manual, right?
Lastly, an advise from me: RTFUM (I get it from other forum), good luck!
Postby phycoman » Wed Oct 07, 2009 2:25 pm
yeah..........
but i mean using software eg. vb2008.........
of course apply voltage across the terminal and it will become a voltage divider.....
my mistaken...............
phycoman
Postby sich » Sat Oct 17, 2009 9:29 pm
Never use PCI7432 card before. I found that it is supported by LabView software. ActiveX Controls for this card are provided too. So maybe u can start from these two directions - write ur program in LabView or VB (by using the ActiveX).
