what should i do to repair my sensor
Postby cole » Sun Oct 18, 2009 2:17 pm
hai, i accidently broken my sunx fx-301 sensor. i accidently connect black wire to gnd n blue wire to 12V. i think the transistor inside already burn. can it be fix? the sensor still can operate. it still can differentiate intensity. the problem is the black wire have no out put, i check the wire is still ok. so what is the problem? please help me.
thank you very much.
cole
Re: what should i do to repair my sensor
Postby ober » Sun Oct 18, 2009 5:54 pm
You are lucky because the sensor is not totally burned. Normally Sun-X do not provide warranty for mis-use. Anyhow, you can send back to Cytron if you bought it from us. We will try to ask whether it can be repaired.....
