motor driver
motor driver
Postby KSW » Wed Sep 15, 2010 12:36 am
there are L293, L293D, L297, L298, how i know which one i need to use?? can introduce one suitable motor driver for me to control Servo motor 360s with maximum speed?? because i want to do speed control in my project :)
KSW
Re: motor driver
Postby ober » Wed Sep 15, 2010 9:07 am
Standard RC servo does not require motor driver.
Re: motor driver
Postby KSW » Wed Sep 15, 2010 10:21 am
IC....then how can i do speed control for 3 servo motor 360s if without motor driver. i check the PIC16F877a datasheet, there is only 2 PWM module at RC1 and RC2. how can i do for third motor if without PWM?? because 3 motors need to run in simaltenous way.
Thank you.
KSW
Re: motor driver
Postby hyng » Wed Sep 15, 2010 10:29 am
What servo motor are you referring? Standard (180 degree) or modified (continuously rotate 360 degree)? If standard motor, maybe you need to get a servo controller such as http://www.cytron.com.my/viewProduct.php?pid=Ly4uGCc9FCskMTMGAi8rJe4NglX6ozDstItiAz5SOrM= to ease your life.
If you are using modified servo motor, then these motors act as normal dc brush motor.You need to use motor driver such as L293D to control it.
Re: motor driver
Postby redips_id » Sat Sep 18, 2010 8:14 pm
If you used 3 units modified servo (continuously rotate 360 degree), you need 2 units of driver motors (either L293D/L298). Since PIC16F877A only have 2 special pins for PWM (CCP1 & CCP2), you can generate your own PWM by using timer interrupt.
redips_id
Re: motor driver
Postby shahrul » Mon Sep 20, 2010 2:11 pm
You may not understand between Servo Motor and DC Motor. Servo Motor operates from pulse input (can't rotate 360 degree), DC Motor continoues rotate if voltage supplied. A modified Servo Motor, it's function as DC Motor.
If standard Servo Motor you use, see http://shahrulnizam.com/pic-lesson-servo-motor/
If modified Servo Motor you use, see http://shahrulnizam.com/pic-lesson-dc-motor/
You have 3 motor, PIC only have 2 PWM, you can combine 2 motor with 1 PWM.
