RF module
RF module
Postby luq1988 » Sat Jan 08, 2011 9:44 pm
Hello,
i wan ask, i hav one project that want to used RF module.
i hav one device and a server. i need to transmit a binary number to the server. Then i need the server to send back i decimal number to the device. so, the question, it is compatible to used the rf module. and how?
my idea ir to connect;
1)RF Transmitter 315MHz
2)RF Receiver 433MHz
with PIC18f452
and
1)RF Transmitter 433MHz
2)RF Receiver 315MHz
with usb connection
but how to connect it
luq1988
Re: RF module
Postby shiyan » Mon Jan 10, 2011 10:04 pm
luq1988 WROTE:1)RF Transmitter 315MHz
with PIC18f452
and
with usb connection
1. You will need 2 UART if you want to send/receive data in serial, right? Will require to develop software UART since PIC18F452 have 1 hardware UART.
2. Try refer to Cytron DIY project, I think they have a set that show 2 board using the RF module to send/receive data.
3. Forgot which volume of ROBOT. Head to Toe. Did talk about this RF module too, need to check with them.
shiyan
Re: RF module
Postby luq1988 » Tue Jan 11, 2011 2:34 am
so it is impossible to connect
with PIC18f452???
but refer to the to Cytron DIY project, it is possible..
how about this case?
with usb connecter.
any one can help??
luq1988
Re: RF module
Postby hyng » Tue Jan 11, 2011 9:37 am
luq1988 WROTE:so it is impossible to connect
with PIC18f452???
with usb connecter.
any one can help??
shiyan never say it is impossible. Please do refer to the DIY project. The concept is basically the same, just that you need another pair of UART. PIC18F do have the libraries for software UART. You may refer to the SD02B sample code. At the USB connection, it is quite challenging. My advise is use UC00A - USB to UART Converter which mean you need another microcontroller at the server part before go to the PC.
Device
PIC18F
1)RF Transmitter 315MHz using hardware UART
2)RF Receiver 433MHz using software UART
Server
PIC18F
1)RF Receiver 315MHz using hardware UART
2)RF Transmitter 433MHz using software UART
3)UC00A to connect to the PC using another software UART
Re: RF module
Postby luq1988 » Tue Jan 11, 2011 6:43 pm
Thank you, it is more clear to me..i will try this..
luq1988
Re: RF module
Postby luq1988 » Tue Jan 11, 2011 6:44 pm
but what the different between hardware UART and software UART?
luq1988
Re: RF module
Postby ober » Tue Jan 11, 2011 9:11 pm
I think shiyan has mistakenly thought you need send and receive on the computer site using another 18F452, therefore will need 2 UARTs.
In your case 1 UART is good enough.
18F452
RX pin - RF Receiver 433MHz
TX pin - RF transmitter 315MHz
USB to UART (is not possible to connect to USB pin directly, there must be a converter)
UART's TX pin - RF Transmitter 433MHz
UART's RX pin - RF Receiver 315MHz
ROBOT. Head to Toe magazine did write an article about this, though is one way communication, but it can help you. It should be volume 4 or 5.
Re: RF module
Postby luq1988 » Wed Jan 12, 2011 10:31 pm
thank you ober.
so i just need 1 pic18f, right?
about sotfware, what kind of software i need to used so that my server can read the data?
luq1988
Re: RF module
Postby sshw » Mon Jan 24, 2011 9:36 pm
can 1 RF module consist different frequency?
how far the distance can it detect?
sshw
Re: RF module
Postby yonghui » Mon Jan 24, 2011 10:38 pm
why u need so many frequencies?
one frequency is enough rit?
