sk40c
sk40c
Postby fatimah » Sun Jan 09, 2011 8:34 am
hello, i want to ask...i have done the programming part, but the hardware part(sk40c), got the problem when i have done with interfacing?what should i do? for vdd and ground, should i used the only one? if yes, which part i should used, left side or right side?
fatimah
Re: sk40c
Postby ABSF » Sun Jan 09, 2011 3:28 pm
You may use Vdd on pins 11 or 32 and GND on pins 12 or 31 of the PIC. Use a voltmeter to confirm the voltage before you conect your external circuit. Connect either to the turn pin socket or the header pins which ever is convenient for you.
You can even use the first 2 pins of JP2 if you dont use the serial interface. Make sure you dont draw too much current from SK40C or else you might toast the 5V regulator.
