fatimah WROTE:hello, i got problem with this device.....after burn the program into ic, this device doesn't function, and i use common cathode method, before that, i check device manually using battery,but it is work....how to solve this problem?
fatimah WROTE:i do refer to seven segment display...i took from laboratory....it doesn't state common cathode or anode , i just realize after i do survey on cytron product regarding this device....
