How to connect RFID to forward reverse motor circuit?
Postby adhha_90 » Fri Mar 11, 2011 1:46 am
I want to connect the motor circuit to RFID which is the motor rotate forward when user scan a tag. Which is the motor act as the output. The problem is where should I connect the motor circuit switch at the RFID board? I had try connect it at L.E.D. port but it doesn't function. Hope anybody can give the solution.
adhha_90
Re: How to connect RFID to forward reverse motor circuit?
Postby shahrul » Fri Mar 11, 2011 5:34 am
Seen that you are not using microcontroller. RFID easily can connect to PIC and DC Motor also easily can connect to PIC using motor driver.
Postby hyng » Fri Mar 11, 2011 2:10 pm
Use RFID to control motor without any main board (microcontroller)? What RFID board you are using? I'm not sure about it. But as far as i know, there should be a main board to interface both module.
Return to RFID
