PR20 problem
PR20 problem
Postby aket88 » Mon Apr 04, 2011 1:51 am
i have bought PR20 DIY kit and read through the document PR20_DD.pdf
i have assemble all the component and recheck the polarity of led and diode b4 solder
im now having problem how to use this diy kit
for example i want to press sw2 on input board to light up the led2 on output board. this is not happening
for x-ctu, i configure accordingly as told in the document
can anyone please help me? thx in advance
aket88
Re: PR20 problem
Postby joliza » Mon Apr 04, 2011 12:23 pm
Have you set the mini jumper according to I/O defined..?
joliza
Re: PR20 problem
Postby aket88 » Mon Apr 04, 2011 12:38 pm
yes
4 example, on the input board, i have to jumper on jp2 while on the output board, i have to jumper on led2.right?
aket88
Re: PR20 problem
Postby sich » Mon Apr 04, 2011 2:06 pm
Did you set the jumpers on both boards correctly? Please follow closely to the Detail Description.
Re: PR20 problem
Postby aket88 » Mon Apr 04, 2011 4:14 pm
i've follow directly from that..
however in the document, it doesnt tell how to configure the jumper..
aket88
Re: PR20 problem
Postby sich » Mon Apr 04, 2011 7:20 pm
Please look at Figure 7 in page 4. The explanation is under the figure.
Re: PR20 problem
Postby aket88 » Mon Apr 04, 2011 9:33 pm
yes,i have refer to page 7 as u said
is there any step missing in the document?
becos i program xbee using x-ctu following the step provided in the document
and in the end it doesnt not function
actually im beginner to xbee.. :geek:
aket88
Re: PR20 problem
Postby ober » Thu Apr 07, 2011 9:49 pm
Hi, can you capture a photo of both board and share it here?
Users browsing this forum: No registered users and 47 guests
