IsaacChuah90 WROTE:Ok...so just use the microchip HI-TECH ANSI C will do right?Just follow the Lesson Mplab in one of your replied comment will right?The coding need to modify if I'm using 16 by 2 lcd instead of using 16 by 4 lcd?because the lcd you using is different with me.thanks for help.New to programming.hope you don't mind.
IsaacChuah90 WROTE:I m sure tat all the pins defined in the software are correctly connected according to the schematic shown in pr12 diy project.I connected my LCD and ds1307 rtc according to the schematic already but it still cant work.the lcd just got light and show nothing.Izit the source code of pr12 used in pic16f876a is different when used in pic16f877a?seeking for helps.Thanks!
