how to use interrupt with SKPS PS2 controller?
Postby gorgom » Wed Nov 16, 2011 10:04 am
I need to use interrupt when the PS2 controller button is pushed. Can anybody show me the example hi-tech C code?
gorgom
Re: how to use interrupt with SKPS PS2 controller?
Postby shahrul » Wed Nov 16, 2011 11:13 am
gorgom WROTE:I need to use interrupt when the PS2 controller button is pushed. Can anybody show me the example hi-tech C code?
Here the code using Hi-Tech for the SKPS PS2.
Postby gorgom » Wed Nov 16, 2011 12:53 pm
thanks shahrul.
static void interrupt isr(void)
if(RCIF==1) status[DATA]=RCREG;
From the interrupt function above, can you explain status[DATA]=RCREG; instruction more detail because the declared variable is unsigned char DATA,status[31];. Sorry, I'm quite new with PIC. :D
gorgom
Postby shahrul » Wed Nov 16, 2011 1:20 pm
gorgom WROTE:thanks shahrul.
Store the status of SKPS protocol. Refer SKPS datasheet, I gather information data 0-28
   if(DATA<28) DATA++;
   else DATA=0;
   uart_transmit(DATA);
Postby gorgom » Wed Nov 16, 2011 2:45 pm
Thanks. I get it now. There is int read_a2d(unsigned char channel); function in the provided source code. But it seem not use in the main program. Can I just delete the function.
gorgom
Postby shahrul » Wed Nov 16, 2011 4:26 pm
gorgom WROTE:Thanks. I get it now. There is int read_a2d(unsigned char channel); function in the provided source code. But it seem not use in the main program. Can I just delete the function.
Yes, you just delete that on re-compile either error or not.
