PR8 with Servo Motor
Postby optitech » Sun Nov 20, 2011 1:07 am
Hai all,
I would like to know, can this DIY connected to the servo motor using the board?
Thanks
optitech
Re: PR8 with Servo Motor
Postby ober » Tue Nov 22, 2011 8:59 pm
Well, is possible. you need to make sure there is available pin and depends which servo motor you want to use, current need to be sufficient as servo motor will draw quite some current when it rotate.
Postby robosang » Fri Nov 25, 2011 9:20 am
Looking through PR8 schematic, I din study it, sorry.... is not my project 8-) .
It seem there are still left RA4, RA5, RC5 and RC6 is not in used by the original design. You can utilize those pins to drive RC servo. Yet, as highlighted by ober, you will need to makesure the supply is sufficient for RC servo and also circuit.
Return to RFID
