hi guys...
where could i find the mosfet IRL520 in area around skudai, johor...
if not possible where the nearest place i can purchase this??
kl84 WROTE:You must use IRL520? What about IRFZ48N? Usually I use it to drive motor. Although the VDSS is only 55V compared to 100V for IRF520, the RDS(ON) is much much lower at only 14mOhm. The lower the better so that the mosfet dissipates little power. Of course there are more parameters that you need to look into before you choose this IRFZ48N...it's just a suggestion if you can't get IRL520 easily.
