hi, my problem is SLD 936 ESD Station not enough hot..even though at maximum temperature..
so, what is problem?soldering station or soldering iron or something else..thank you..
ABSF WROTE:Any specs or picture of your soldering station? Was it using 24V dc or something else? Does it has digital temperature display?
I have a soldering station made in China. But later I found that the heat sensor inside the iron becomes intermittent so I replaced it with the spare iron. The iron has a plug with 4 wires and is quite hard to get. I also have another Weller TCP soldering iron operating on 48V DC/AC. This iron is very reliable and has lasted me many years.
goodstudent WROTE:hi, my problem is SLD 936 ESD Station not enough hot..even though at maximum temperature..
goodstudent WROTE: where the heat sensor is?
it is in soldering iron with white color?
where i can get it?
