Enquiry on motor driver FD04A
Postby tungyc » Wed Jan 11, 2012 8:00 pm
Hi, I would want to know how to control the speed of this driver. As from the manual you gave, if no PWM the 5v will straight away act as the PWM? By the way I'm using mbed to control this motor driver.
Is looking forward for your reply. Thank you
tungyc
Re: Enquiry on motor driver FD04A
Postby hyng » Sat Jan 14, 2012 11:10 am
Hi, there is sample project of FD04A name PR19. You can refer to it. The sample source code is also given.
http://www.cytron.com.my/viewProduct.php?pid=EjgZPDciExkkJTY5BAYjIeBpPkmZooCOMTLGzOojw7Y=&store=
Postby tungyc » Sat Jan 14, 2012 5:13 pm
Thank you for your prompt reply.. The pr19 you said, that one is for pic.. I just want to know is it supply 0 to 5v to PWM can control the speed? Or must use plus?
tungyc
Postby robosang » Sat Jan 14, 2012 6:01 pm
I guess you have to use pulses, most of the motor driver uses that. Of course you want it to be full speed, just simply tie it to 5V, that channel will offer full speed to load, yet it will still depends on the In1 and In2.
Postby tungyc » Sun Jan 15, 2012 7:39 pm
Thank you
tungyc
Return to Hardware
