SK40C Beginner
SK40C Beginner
Postby vick5821 » Tue Jan 31, 2012 8:09 pm
Hey guys, I have just got my SK40C today!!! Damn excited.However, I do not know how to start ? I downloaded the code from cytron tutorial websites but it build failed in MPLAB IDE..
how to solve it ?
This is the error msg :(
vick5821
Re: SK40C Beginner
Postby robosang » Tue Jan 31, 2012 8:59 pm
Printscreen the whole MPLAB IDE, show us the project window.
Re: SK40C Beginner
Postby nazfar » Wed Feb 01, 2012 3:01 pm
It is because your compiler does not recognize the library of "system.h" for your MC. Based on my experience, i am using PIC16F877A and using the library as same as you do but after I removed the library, it works ;) and my program working as I expected. I think it is because of your MC do not have such library to call. I hope it helps you ;)
nazfar
Re: SK40C Beginner
Postby vick5821 » Wed Feb 01, 2012 3:48 pm
vick5821
Re: SK40C Beginner
Postby vick5821 » Wed Feb 01, 2012 3:49 pm
nazfar WROTE:It is because your compiler does not recognize the library of "system.h" for your MC. Based on my experience, i am using PIC16F877A and using the library as same as you do but after I removed the library, it works ;) and my program working as I expected. I think it is because of your MC do not have such library to call. I hope it helps you ;)
Then what should I do ?
vick5821
Re: SK40C Beginner
Postby robosang » Wed Feb 01, 2012 9:20 pm
Ober, you are right, I have that problem too. Why is HI-TECH changing it? Really not convenience to us. I have to change all my old code accordingly. Worst, they also change some of the register name, such as ADGO become AD_GODONE. :o
Re: SK40C Beginner
Postby vick5821 » Wed Feb 01, 2012 10:29 pm
#include <pic.h>
__CONFIG ( 0x3F32 );
#define LED_1 RC3
#define LED_2 RC2
#define LED_3 RA0
void init(void);
void main(void)
init();
for(int i=0;i<3;i++)
LED_1=1;
LED_2=0;
delay(100000);
LED_1=0;
LED_2=1;
delay(100000);
LED_1=0;
LED_2=0;
LED_3=1;
delay(100000);
LED_1=0;
LED_2=1;
LED_3=0;
delay(100000);
for(int j=0;j<3;j++)
LED_1 =1;
LED_2=1;
LED_3=1;
delay(100000);
void init()
TRISA=0b00000000;
TRISB=0b00000000;
TRISC=0b00000000;
TRISD=0b00000000;
TRISE=0b00000000;
void delay(unsigned long data) //delay function, the delay time
for( ;data>0;data-=1); //depend on the given value
This is my code, and this is how it operate..Weird working based on code right? anyone can tell me why ?
http://www.youtube.com/watch?v=egRCZTx3 ... e=youtu.be
vick5821
Re: SK40C Beginner
Postby ABSF » Thu Feb 02, 2012 7:05 am
LED_1 =1;
LED_2=1;
LED_3=1;
delay(100000);
If you are expecting the above code to flash the 3 LED for 3 times, you wont be able to get it. Think about it over carefully. The rest of the video matches your code.
