Urgent! Diffuse sensor help!
Postby hellokitty9999 » Mon Feb 13, 2012 9:59 am
Hi, I have a diffuse sensor(PZ2-42 keyence sensor). Does anybody know the sensor output voltage and the voltage drop when the sensor sense something??
Information on the sensor:
http://www.alltronics.com/mas_assets/acrobat/24P006.pdf
Thank you
hellokitty9999
Re: Urgent! Diffuse sensor help!
Postby kl84 » Mon Feb 13, 2012 10:52 am
The output should be digital signal, HIGH or LOW. You can switch the output to give HIGH when it detects object in its range or to give LOW when the same condition occurs.
kl84
Postby robosang » Mon Feb 13, 2012 11:19 am
besides what kl84 highlighted, I think you should take a look at another thread:http://forum.cytron.com.my/viewtopic.php?f=7&t=11406
Looking at the datasheet, it is NPN output sensor, you will need to pull up.
Postby hellokitty9999 » Tue Feb 14, 2012 9:18 am
Hi, do I need to put a resistor between the Vcc and the output?? And how to do the switch output HIGH when it detect objects??
hellokitty9999
Postby ABSF » Tue Feb 14, 2012 11:01 am
There are 2 ways:
1. Change your software to detect active Low instead of active High.
2. Use another NPN transistor to invert the signal.
Postby robosang » Wed Feb 15, 2012 11:17 am
The sensor should have turnable knob, and there should be label of "L" and "D". Turn it and look at the output.
Postby hellokitty9999 » Wed Feb 15, 2012 5:30 pm
ok. Thanks!
hellokitty9999
