Bluetooth (SKKCA-21) Remote Control for window mobile phone
Postby cheekangteh » Sat Feb 25, 2012 8:29 am
hi, i am new to this kit.
May i know, this kit can used for sending signal to window mobile phone to trigger a window mobile phone or not? the function can act like handphone headset?
For example:
when i press a button at headset button it will automatic trigger the mobile phone call button and listen to the phone.
i wish to use Bluetooth (SKKCA-21) Remote Control for trigger my window mobile sms button.
For example
i will add a button and connect to pic that already program with "Bluetooth (SKKCA-21) Remote Control", once the button pressed, it will send a signal to window mobile phone and trigger a sms button.
i wish to double confirm, Bluetooth (SKKCA-21) Remote Control can perform this senario or not? kindly advice. thanks a lot
cheekangteh
Re: Bluetooth (SKKCA-21) Remote Control for window mobile ph
Postby ober » Mon Feb 27, 2012 9:19 pm
Not sure about that, but SKKCA-21 only support Serial Port Profile, SPP in short. Most smart phone have serial port for user to write program. So you might need to explore whether serial port can access to your button.
Postby cheekangteh » Sun Mar 04, 2012 1:56 pm
ober WROTE:Not sure about that, but SKKCA-21 only support Serial Port Profile, SPP in short. Most smart phone have serial port for user to write program. So you might need to explore whether serial port can access to your button.
Hi ober, thanks for the comment. After i researched, mobile phone (serial port) can access and get data from the device.
may i know the sequence by using skcca-21?
am i right?
1. skcca-21 pair with other bluetooth device.
2. skcca-21 can communicate with the pairing device after pairing.
my question:
How we set the command to SKKCA-21? if i wish to ask the SKCCA-21 send a signal (message or any file) to window mobile?
(i will program a sending function in my PIC, after the button was pressed, the pic will ask the skcca-21 to send a signal to user)
may i know what is the AT Command for Skcca-21 to send a signal? or send a file? kindly advice. tq
and where can i find the AT Command file?
cheekangteh
Postby cheekangteh » Sun Mar 04, 2012 3:31 pm
after i make an deeply research... i found the AT command file :D .
now i just want to make sure that my idea is correct or not.
1. i will solder PIC to SKCCA-21.
2. i used PIC control the SKCCA-21.
how PIC control the SKCCA-21?
3. I program the PIC by using the AT-Command. (like sending a file and signal)
am i right? kindly advice, and give me a clear direction. tq
cheekangteh
Postby sich » Mon Mar 05, 2012 10:35 am
Have you gone through the user manual and other related documents in SKKCA-21 product page?
