bluetooth connection via vb to control motor
Postby aziz » Wed Mar 17, 2010 10:01 pm
hi, ro8 now i'm doing a project deal with bluetooth. i want to know how v=can we control the motor by using the bluetooth as a controller with aid from vb. for example: if we press the forward button at vb from the laptop, the robot or motor can move forward. the connection is use bluetooth skkca-21 at robot and bluetooth doggle at laptop. can u give or tell me some idea to do it.
thanks.
aziz
Re: bluetooth connection via vb to control motor
Postby ober » Sat Mar 20, 2010 2:37 pm
Basically when Bluetooth dongle from your computer connect to SKKCA-21, it will provide a new COM port.
Write a program to access/send command to COM port. The command then will be send to SKKCA-21 and further to your robot.
On your robot, you must also develop a program to process the command receive and decide what to do with it.
Postby abam kacak » Wed Mar 14, 2012 2:02 am
can you give me some example for source code in VB10?
abam kacak
Postby robosang » Wed Mar 14, 2012 9:02 pm
how about VB9, 8, 7? Labview maybe? Visual C#, Visual C++, Matlab, Pascal, :mrgreen:
Postby shahrul » Wed Mar 14, 2012 10:05 pm
abam kacak WROTE:can you give me some example for source code in VB10?
VB Serial Communication
