#include <htc.h>
#include <pic.h>
__CONFIG ( 0x3F32 );
#define rs RC4
#define e RC5
#define lcd_data PORTB
void send_string(const char *s);
void lcd_clr(void);
unsigned char location=1;
void main(void)
TRISB = 0b00000000;
TRISC = 0b10000000;
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //lcd return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //display on, cursor off and cursor blink off
send_config(0b00111000); //function set
lcd_clr();
lcd_goto(0);
send_string("ND2/11/CME");
lcd_goto(20);
send_string("MKJB");
delay(200000);
lcd_clr();
rs=0;
lcd_data = data;
e=1;
delay(50);
e=0;
delay(50);
void lcd_clr(void)
send_config(0x01);
delay(600);
for( ;data>0;data--);
void lcd_goto(unsigned char data) //set the location of the lcd cursor
{ //if the given value is (0-15) the
if(data<16) //cursor will be at the upper line
{ //if the given value is (20-35) the
send_config(0x80+data); //cursor will be at the lower line
} //location of the lcd cursor(2X16):
else // -----------------------------------------------------
{ // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
data=data-20; // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
send_config(0xc0+data); // -----------------------------------------------------
void send_string(const char *s) //send a string to display in the lcd
unsigned char i=0;
while (s && *s)send_char (*s++);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay(10);
e=0;
delay(10);
Users browsing this forum: No registered users and 39 guests
