PIC driving 2x LED displays directly (16f884)
Re: PIC driving 2x LED displays directly (16f884)
Postby takao21203 » Sun Apr 08, 2012 11:04 pm
this is the displays @ 3 volt, and a graphite cartoon character that I made.
hosted @ photobucket, the image is only 3.9K, if you wish to see it, click the link to photobucket.
By the way I wrote the source in C.
The order of the multiplex can be reprogrammed easily.
takao21203
Postby takao21203 » Mon Apr 09, 2012 12:00 am
I have added a hex keypad.
There is a tension element to pull together the two PCBs. The gap between the LED displays wires and the new PCB is 2mm!
And it is under great tension.
I use lead solder it's possible to deposit solder tabs.
the keypad: http://i25.photobucket.com/albums/c69/n ... puter2.jpg
http://i25.photobucket.com/albums/c69/n ... yboard.jpg
solder tabs to secure the keypad. It's like one big PCB.
takao21203
Postby takao21203 » Mon May 07, 2012 6:30 am
I have built this circuit into Voltmeter / Amp. Meter (only voltmeter works as for now).
-Supply 3.3 volts using 2576 dc/dc converter IC, from 12v electronic transformer
-Jumper select to 5 volts (modifying 2576 3.3 using a LED)
-7805 chip as voltage reference (12v --> 2.5v)
More than 1K codespace is used by using a few lines code, having two float variables!
And this takes so long to execute, I had to remove it from ISR, or refresh becomes disturbed.
No damage to display, PIC chip = cool (at 3.3V), have this working now for weeks, sometimes 24 hours.
Resistor free...
takao21203
Previous
