PR31
PR31
Postby Ir Anwar » Wed Jul 11, 2012 4:36 pm
Hello..
For PR31, IC can program thru with usb to uart converter?
What accessories should need to do this project?
Ir Anwar
Re: PR31
Postby robosang » Wed Jul 11, 2012 10:14 pm
Er? Another Cytron's DIY project?
I think most, or all of Cytron's DIY project uses PIC microcontroller, and as far as I know, they uses ICSP to load program. USB to UART converter is normally use for bootloader, such as Arduino.
Re: PR31
Postby Ir Anwar » Wed Jul 11, 2012 11:20 pm
PR31 is Digital Radio with BB-AR1010.
I know that this project requires the ICSP to load the program, but in PR31 have a connection to the USB to UART converter. Does this project require SK40C? and any additional accessories needed in this project?
Ir Anwar
Re: PR31
Postby ober » Thu Jul 12, 2012 10:18 am
Ir Anwar WROTE:PR31 is Digital Radio with BB-AR1010.
Yup, the PR31 is another DIY project from Cytron, but we have discontinued it because some of the parts have been discontinued, particularly the BB-AR1010. USB to UART is not being used for loading program but just an optional item for UART communication because on the PR31 PCB, the designer reserve the UART port. Since the example code also have function to send the station frequency to computer, you can utilize it if you want. Again, that is optional.
All our DIY project that uses PIC microcontroller utilize the UIC00A/B to load program. SK40C is no needed if you have the PR31 set, but since we do not have this set anymore, you can use SK40C with the PIC16F877A to connect the circuit and load the sample code. All information can be obtain from the product page of PR31. Look at the Detailed Description should answer most of your doubt.
Re: PR31
Postby Ir Anwar » Mon Jul 23, 2012 1:50 pm
what is the appropriate MPLAB to make PR31? the microchip website, no version of MPLAB V8.10. MPLAB is how suitable for download?
Ir Anwar
Re: PR31
Postby robosang » Thu Jul 26, 2012 8:41 pm
Er....I thought the DIY product page should have MPLAB for download. Actually you can download from Microchip just you need to dig in deep, they have an archive link :mrgreen:
Re: PR31
Postby holly14 » Mon Jan 26, 2015 11:08 pm
If im not mistaken, there is no such command to check the particular user id. You can only add, delete, match and request for total number of id.
Our excellent online pass-4sure training programs will lead you to success in the We als offer latest and pass 4 sure with 100% success guarantee. Our northeastern is rare in IT world.
holly14
Return to DIY Project Set
