pr11 help anyone?
pr11 help anyone?
Postby black_smtk » Tue Sep 11, 2012 9:58 am
i already assemble the components. when programming, i try to connect it say there "Found PICkit 2 - Operating System Version 2.32.0
PICkit 2 Unit ID = UIC00B V1.0
Target power not detected - Powering from PICkit 2 ( 5.00V)
PIC16F876A found (Rev 0x8)
PICkit 2 Ready"
what is the problem? can any1 help me??? :cry: :cry:
even the lcd didnt turn on?
black_smtk
Re: pr11 help anyone?
Postby yonghui » Tue Sep 11, 2012 10:40 am
have u try to power it up with battery or ac dc adaptor?
Postby hyng » Tue Sep 11, 2012 1:49 pm
Few photos of the connection may help to identify the problem...
Postby black_smtk » Tue Sep 11, 2012 2:48 pm
already supply with 9v +3v batteries give about 11.3V. already solder all components on the manufacturer pcb for testing. still cannot program. the programmer red light turn on. i dont know whats the problem.
black_smtk
Postby black_smtk » Tue Sep 11, 2012 2:59 pm
here are some of the pictures.
red led on means error right?
black_smtk
Postby gadgetng » Tue Sep 11, 2012 3:09 pm
Double check again the soldering and connection if you got a multimeter. Last time my project also cannot be programmed until some soldering and connection problem were solved. Actually you just only need to check the ICSP and MCLR pins which are for programming purpose. If you don't know where it is, check the schematic that provided by cytron.
gadgetng
Postby black_smtk » Tue Sep 11, 2012 3:35 pm
thanks :D ..i'll try that.
black_smtk
Postby black_smtk » Tue Sep 11, 2012 10:51 pm
had try troubleshoot by multimeter. nothing seems wrong. soldering back. still cannot program. red light still on at programmer. :( . desolder back. pcb cannot be used anymore. just had order new components. :( ..gonna make my own circuit.
black_smtk
Postby gadgetng » Wed Sep 12, 2012 1:33 pm
Oh? ur programmer got problem?
Detach the programmer from the pcb board. What will happen to the programmer? Is your PC able to detect the programmer?
gadgetng
Postby black_smtk » Mon Sep 17, 2012 10:53 pm
my programmer is o.k. only when i try to program, it says there is not enough power supply. so cannot program. i think i'll just proceed modifying the project for my fyp. :roll:
black_smtk
Return to DIY Project Set
