PR26 - game contoller not detected
Postby internetscooter » Fri Oct 19, 2012 5:08 pm
It looks like I have done everything right but my game controller is not detected Linux/Windows 7/Mac. Nothing pops up like it is trying to install something and fails, just does nothing...
Here is my diagnostic info:
* Green PWR led is on (power getting through from USB)
* I can program, read, erase, read (zeros), program, read (program) and verify (red light flashes)
Verifying Target
PIC18F2550 found (Rev 0x7)
Verifying Program Memory (0x0 - 0x7FFF)
Verifying EEPROM Memory (0x0 - 0xFF)
Verifying User ID Memory
Verifying Configuration Memory
PICkit 2 Ready
* Once suspicous thing is the message about power
Found PICkit 2 - Operating System Version 2.32.0
PICkit 2 Unit ID = UIC00B V1.0
[b]Target power not detected - Powering from PICkit 2 ( 5.00V)[/b]
PICkit 2 Ready
All the jumpers are there and there appears to be no shorts - any suggests on what it could be?
Below shows the code builds ok and the versions I use - any help appreciated!
Paul
Release build of project `D:\max\GameController\MaxGameController\MaxGameController.mcp' started.
Language tool versions: mpasmwin.exe v5.46, mplink.exe v4.44, mcc18.exe v3.43, mplib.exe v4.44
Fri Oct 19 20:06:40 2012
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_device.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_function_hid.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\main.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_descriptors.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\MaxGameController.cof".
Clean: Deleted file "D:\max\GameController\MaxGameController\MaxGameController.hex".
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_device.c" -fo="usb_device.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_function_hid.c" -fo="usb_function_hid.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_descriptors.c" -fo="usb_descriptors.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mplink.exe" /p18F2550 "..\Source Code PR26\Source Code PR26\rm18f2550 - HID Bootload.lkr" "usb_device.o" "usb_function_hid.o" "main.o" "usb_descriptors.o" /u_CRUNTIME /z__MPLAB_BUILD=1 /o"MaxGameController.cof" /M"MaxGameController.map" /W
MPLINK 4.44, Linker
Device Database Version 1.9
Copyright (c) 1998-2011 Microchip Technology Inc.
Errors    : 0
MP2HEX 4.44, COFF to HEX File Converter
Errors    : 0
Loaded D:\max\GameController\MaxGameController\MaxGameController.cof.
Release build of project `D:\max\GameController\MaxGameController\MaxGameController.mcp' succeeded.
Fri Oct 19 20:06:44 2012
BUILD SUCCEEDED
internetscooter
Re: PR26 - game contoller not detected
Postby robosang » Fri Oct 19, 2012 6:34 pm
PR26? Oh... this is the USB game controller using PIC18F2550, right? One of DIY project of Cytron. I did refer to this project when I start with PIC18F2550, playing the USB features.
I would suggest a photo of hardware would be good.
Postby yonghui » Fri Oct 19, 2012 9:34 pm
u try to check the device manager, see if any HID device detected?
programming the pic without powering the pic will cause the pickit2 to power up the pic when programming, this is normal.
Postby internetscooter » Sat Oct 20, 2012 6:03 am
Here's a low res pic...
And a higher res one can be found here...
http://files.internetscooter.com/misc/PR26_USB_GameController.JPG
To program it, it needs its USB plugged in for power. So power should be there (and the PWR light is on). Maybe that is one area to concentrate on.
I am also guessing I should be able to debug the code and see what it is doing USB wise by putting in break points and hitting the reset button.
Paul
internetscooter
Postby robosang » Sat Oct 20, 2012 8:20 am
Nice photo, but seem like good soldering work, yet to see the bottom layer :)
Anyway, from my previous experience, if the USB does not work, it might because of several reasons:
1. USB cable
2. Reset is not pull high properly, PIC cannot run code
3. Capacitor at Vusb is not working properly, or wrong polarity, or not soldered properly
4. Crystal is not working or solder properly, causing PIC not to run the code in right timing, USB require high accuracy of timing
5. Last and not least, the code is not loaded :)
Postby internetscooter » Sat Oct 20, 2012 1:37 pm
Thanks for the tips, I will report how I go... here's the back, a few splats but nothing obvious which would short semething out...
And the higher res:
http://files.internetscooter.com/misc/PR26_rear.JPG
Hopefully a positive update soon :)
Paul
internetscooter
Postby yonghui » Mon Oct 22, 2012 11:09 am
try to clean the soldering using a brush.
its quite hard to see with bare eye what happened to the circuit.
try to check the Vdd of the PIC using multimeter when powering up with USB, try to check the MCLR pin whether its pull up when powered.
Postby internetscooter » Mon Oct 22, 2012 4:43 pm
Thanks everyone for the help - it turned out that crystal clock timing was the problem. I had not paid close attention to the capacitors and assumed they were all the same, however there were two that were 30pF which were intended for the crystal and I had stuck them elsewhere :(
All fixed now and working :)
Cheers,
Paul
internetscooter
Postby robosang » Mon Oct 22, 2012 6:31 pm
Woh! Miss that from the picture :) Good to hear it is working!
Return to DIY Project Set
