[HELP] PR23 Multifunction Mobile Robot
Re: [HELP] PR23 Multifunction Mobile Robot
Postby NSH » Thu Oct 18, 2012 5:08 pm
Hi Gadgetng,
Thanks for the reply.
It's a data conflict error. But I don't really get it. What does it mean?
What can I do?
NSH
Postby yonghui » Thu Oct 18, 2012 11:15 pm
not sure, what if u try to delete the Hex code in the folder then rebuild.
Postby NSH » Mon Nov 05, 2012 8:50 pm
Thanks yonghui...thank u so much :)
Anyway, can anyone solve my problem? Im lost when I tried to modify this module.
I would like to modify the Ultrasonic Part.
I would like to ask that how could I modify it so that it could stop when it senses there is an obstacle in front with a distance of 2cm, and then it will STOP itself and move BACKWARD, turn to RIGHT or LEFT, and move FORWARD.
I know it is just a simple step. But I failed to do so. :?
Can anyone teach me?
I appreciate it...thank you :)
NSH
Postby robosang » Tue Nov 06, 2012 8:46 pm
Never see this error before :)
Postby NSH » Tue Nov 06, 2012 9:39 pm
Hi Robosang, thanks for your reply.
Anyway, Im trying to modify the codes so that the device could stop and move backward and then turn to right or left once it senses an obstacle in front of it through the Ultrasonic Sensor.
Do you have some ideas?
Thank you :)
NSH
Postby robosang » Wed Nov 07, 2012 6:14 pm
You cannot compile, what's the use of modifying it?
And sorry, I don help people do homework 8-)
Postby zhenning » Tue Nov 13, 2012 12:57 am
By changing the value of the distance should not cause you any error on recompiling the project. Are you able to compile the original code? If yes, delete all the generated files leaving only the source file. Then, recompile. I am able to compile them here even after i change the distance.
zhenning
Postby gadgetng » Tue Nov 13, 2012 2:00 pm
Try to solve the error first before you modify it.
gadgetng
Previous
Return to DIY Project Set
