Zigbee+Adruino+motor
Postby HIIKIEWHUI » Thu Nov 22, 2012 7:29 pm
here i wanna to ask that is it the driver is need if i use the combination of Zigbee + Arduino Uno with the Minebea Stepping Motor ? Thanks
Regards
HIIKIEWHUI
Re: Zigbee+Adruino+motor
Postby robosang » Thu Nov 22, 2012 8:17 pm
Sure need motor driver :twisted:
Postby zhenning » Thu Nov 22, 2012 8:24 pm
Yeah. You need a stepper motor driver
zhenning
Postby HIIKIEWHUI » Fri Nov 23, 2012 1:21 am
Is is possible that i get the drive to control the motor without the adruino? :?
Thanks
Regards :?
HIIKIEWHUI
Postby zhenning » Fri Nov 23, 2012 3:04 am
HIIKIEWHUI WROTE:Hi,
Thanks
Regards :?
Yes you can. see this: http://www.simplecircuitdiagram.com/200 ... er-needed/
zhenning
Postby HIIKIEWHUI » Fri Nov 23, 2012 10:46 am
:o Thanks for the answer, i appreciate it.
Somethings that i am not clear is since i use one the Starter kit of my Zigbee connects to my computer as the transmitter and the other side the Zigbee chip is connected to the adruino and the motor by the expansion board as the receriver, does it works? As i use to program the microcontroller on the Arduino by using the software given, is it anything i need to do with my Zigbee?
Regards
HIIKIEWHUI
Postby zhenning » Fri Nov 23, 2012 11:04 am
Regards
You first need to program and configure your xbee: http://www.cytron.com.my/datasheet/Wire ... 20Test.pdf
Then, you can use your XBee as if its writing to uart or reading from uart.
zhenning
