Interfacing waterproof temperature & humidity sensor
Postby ale7beck » Thu Nov 29, 2012 12:14 am
How to interface waterproof temperature & humidity sensor using Intel® Atom™ Processor E6xx Series?
ale7beck
Re: Interfacing waterproof temperature & humidity sensor
Postby robosang » Thu Nov 29, 2012 8:38 am
No idea.... what is the interfacing voltage of Atom processor?? ADC?
Postby ale7beck » Thu Nov 29, 2012 9:17 am
12V external supply. I'm not sure with the ADC but I think it doesn't have one. Is't possible to connect directly?
ale7beck
Postby ale7beck » Thu Nov 29, 2012 11:59 am
I just check another datasheet for Intel Atom E6xx series, it has 2 input 10-bits ADC for signal measurements.
ale7beck
Postby robosang » Fri Nov 30, 2012 9:41 am
You need to know whether it can withstand 5V or 3.3V, because the sensor need that voltage, and if the sensor is analog output, it might output up to 5V.
