Attendance system
Re: Attendance system
Postby zhenning » Sun Dec 16, 2012 5:20 pm
There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
zhenning
Postby Marvin_G » Sun Dec 16, 2012 9:40 pm
zhenning WROTE:There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
when i use fdisk -l command,i cant see the UC00B. Any suggestion?
Marvin_G
Postby Marvin_G » Sun Dec 16, 2012 9:43 pm
i tried this command "dmesg | grep tty" (not really sure what it means) and it said that pl2303 converter iw now attached to ttyUSB0. is it useful?
Marvin_G
Postby zhenning » Mon Dec 17, 2012 9:31 am
So,it is recognized. What are you trying to do by just sending 0xF5?
zhenning
Postby Marvin_G » Mon Dec 17, 2012 10:10 am
but even if i didn't connect the UC00B,it still said pl2303 converter is now attached to ttyUSB0. why is that?
Marvin_G
Postby Marvin_G » Mon Dec 17, 2012 10:11 am
do i really need to put the "" thing when writing the command to the device?
Marvin_G
Postby zhenning » Mon Dec 17, 2012 10:40 am
Marvin_G WROTE:do i really need to put the "" thing when writing the command to the device?
Yes you need that. What are you trying to do first? I believe there is one row of commands rather than just 0xF5?
zhenning
Postby Marvin_G » Mon Dec 17, 2012 11:51 am
if you can go to this link and download it's manual you might can help me because i don't really know how the command works. http://www.cytron.com.my/viewProduct.ph ... er%20(UART)
yes theres a row of command such as " 0xF50xF5000000xF5 " this command is for deleting all the data inside the DSP processor of the fingerprint reader.
Marvin_G
Postby gadgetng » Mon Dec 17, 2012 2:02 pm
Try see what is the response after you giving the command. Maybe you can have some clue from them.
gadgetng
Postby Marvin_G » Mon Dec 17, 2012 3:34 pm
gadgetng WROTE:Try see what is the response after you giving the command. Maybe you can have some clue from them.
as i told before. no response.
Marvin_G
PreviousNext
Return to Misc Project
