Fingerprint reader (UART) SN-FPR-UART
Postby Marvin_G » Mon Dec 17, 2012 5:50 pm
Hye guys, anyone used Fingerprint reader (UART) SN-FPR-UART before? i wanted to know how can i get all data in the DSP processor at once.
Marvin_G
Re: Fingerprint reader (UART) SN-FPR-UART
Postby gadgetng » Mon Dec 17, 2012 7:50 pm
Yes. I used the fingerprint with PIC before. It is also working fine with the VB provided when i testing it for the first time with UC00A.
gadgetng
Postby shahrul » Mon Dec 17, 2012 8:14 pm
I use Fingerprint Reader but not try to get all data or image.
Postby Marvin_G » Tue Dec 18, 2012 10:42 am
gadgetng WROTE:Yes. I used the fingerprint with PIC before. It is also working fine with the VB provided when i testing it for the first time with UC00A.
nice. so basically you just send command based on the manual is it?
Marvin_G
Postby gadgetng » Tue Dec 18, 2012 10:44 am
Also refer to PR29, diy kit.
gadgetng
Postby Marvin_G » Wed Dec 19, 2012 4:08 pm
shahrul WROTE:I use Fingerprint Reader but not try to get all data or image.
i'm using linux and i wanted to send command to the device but failed. below is my command:
echo "0xF5,0x01,0x00,0x01,0x03,0,0x03,0xF5" >/dev/ttyUSB0
i also used cutecom to send those command but the device does not give any respond. Any idea why?
Marvin_G
Postby zhenning » Wed Dec 19, 2012 11:25 pm
Please stop posting in multiple post. Just stick to one since your problem is the same problem. Easier for people to reply and read.
zhenning
Postby robosang » Thu Dec 20, 2012 10:04 am
Agreed with zhenning :mrgreen:
Postby thinkpositivex » Sat Dec 29, 2012 8:48 pm
dear all...
i'm a new in fingerprint reader (UART) SN-FPR-UART ...i have a question regarding on this product because after all connection is connected i run on visual basic8 ,select baud rate 19200 and open port 8 detected as per stated on manual but unfortunately this system hang and i no window show connection successfully.another question is hyper terminal,is it compulsory to run this finger print with hyper terminal and it effect,pls explained and advice me.....thank you... :P...
thinkpositivex
Postby zhenning » Sat Dec 29, 2012 9:34 pm
thinkpositivex WROTE:another question is hyper terminal,is it compulsory to run this finger print with hyper terminal and it effect
Did it work on hyperterminal?
zhenning
Return to DIY Project Set
