crystal oscillator
crystal oscillator
Postby big nose » Fri Jan 04, 2013 4:03 pm
hello..... :D
I am doing a burglar alarm in which I used pic16f877a. On the process of doing this project I encountered problems regarding the crystal oscillator. Why is it that it needs to be discharge first or I need to touch it every time for the whole system to function?have you also experienced this problem? do you have any idea how to get rid of this? please we need the answers ASAP...
big nose
Re: crystal oscillator
Postby shahrul » Fri Jan 04, 2013 7:21 pm
big nose WROTE:hello..... :D
I never experienced. I wonder how your soldering hardware and how your crystal position. So, can you show your hardware picture?
Postby zhenning » Fri Jan 04, 2013 7:42 pm
Did you tie the MCLR pin to VDD?
zhenning
Postby big nose » Sat Jan 05, 2013 1:40 pm
no, I did not connect the MCLR to Vdd.
is it that necessary to connect it??
also to shahrul, were quiet confident on the way we soldered it. And i think there is no issue on the crystal position coz it has no polarity.....thanks for the concern anyway.... :D
big nose
Postby zhenning » Sat Jan 05, 2013 2:22 pm
big nose WROTE:no, I did not connect the MCLR to Vdd.
Yes, of course you need to connect that through 10k resistor. That pin is a master clear reset pin. If it is connected to ground, then your circuit will reset. So, if you leave the pin floating, it will be any value.
zhenning
Postby big nose » Mon Jan 07, 2013 4:27 pm
ohhh...sorry,i did not notice that it is already connected.
it is attached with a 4.7k resistor with the reset button as it go through the Vdd. and the Vdd was with a capacitor as it go along to the MCLR.
big nose
Postby Idris » Tue Jan 08, 2013 9:49 am
Replace the Crystal. Could you post your hardware picture?
Postby big nose » Wed Jan 09, 2013 5:08 pm
we already replaced it a couple of times but still the outcome is the same.
big nose
Postby sich » Wed Jan 09, 2013 5:28 pm
Please post your hardware connection. Using breadboard? Etch own PCB?... All these are important to know your circuit better. This problem usually occurs when the there's open connection somewhere.
Postby big nose » Thu Jan 10, 2013 8:33 am
somehow we already found a way on how to solve it.
and i guess we did the right thing because the crystal oscillator is now functioning well.
thank you guys for being such a help we really appreciate it.
big nose
