sustainable turbine flow meter
If you have any suggestion or proposal that would like to share with us, please post it here. Thanks.
Postby aminto89 » Tue Feb 26, 2013 1:48 am
Hi..
i am a final year student i would like to get some suggestion and guidance regarding
my final year project(fyp).
i am going to do a project on sustainable flowmeter.i am planning to use the turbine flowmeter and the wind turbine concept
to generate electric as the power supply for the flowmeter to function.therefore,i would like some suggestion or opinion on this project.
it is possible to connect the turbine flow meter and the generator (to generate electric)??
what type of generator that i need to use??
do u have turbine flowmeter and generator??
thank you..
regards..
aminto89
Re: sustainable turbine flow meter
Postby yonghui » Tue Feb 26, 2013 9:55 am
can u explain more in simple words?
what is the use of the flow meter? is it to measure the rotation speed of turbine?
your turbine is is wind turbine?
i thought that the wind turbine is for generating electric. wind turbine is connected to the generator.
Postby aminto89 » Tue Feb 26, 2013 4:06 pm
hi..
thx 4 the reply..
im using the turbine flow meter to measure the flow rate of flowing fluid in pipe..
the flow meter will get the electricity (power supply) by generating itself..
the idea is to use the same concept as wind turbine..as the the turbine will connected to a generator..
so as turbine flow meter,im planing to connect it with a generator..im not planning to generate large amount of voltage..
just enough to use it to make the flow meter functioning..
is it possible to do it?? any suggestions??
really appreciate if u can help me :)
aminto89
Postby yonghui » Wed Feb 27, 2013 11:05 am
do you have the turbine already?
Postby yonghui » Wed Feb 27, 2013 11:22 am
probably u will like this :
G 1/2 Water Flow Sensor
http://cytron.com.my/viewProduct.php?pc ... w%20Sensor
Postby aminto89 » Thu Feb 28, 2013 10:51 pm
thx for the info..
stil dun have the turbine yet..
but can i connect the turbine with dc motor??
if i want to generate a 5-12v electricity,which dc motor that i must use?
aminto89
Postby yonghui » Fri Mar 01, 2013 9:44 am
it depends on how much power your turbine can generate. and how much electric power your motor will consume.
Return to Ideas for New Products
