PR29
PR29
Postby hui » Tue Feb 19, 2013 10:22 pm
Can fingerprint reader module import fingerprint image to MATLAB software?
hui
Re: PR29
Postby robosang » Wed Feb 20, 2013 9:00 am
Don have the hardware to verify that, but if it is UART and MATLAB can access to COM port, there should not be problem.
Re: PR29
Postby yonghui » Wed Feb 20, 2013 12:04 pm
u need the image file to process by your own algorithm in Matlab?
then u will need to verify whether the module can send out the fingerprint image or not. what i know is that the module has on board dsp processor to process the images.
Re: PR29
Postby hui » Thu Mar 14, 2013 10:22 pm
is it possible the PR29 act as standalone project by edit the code in mplab?
my project is about simple security system, just display door open for certain person and invalid for other.
hui
Re: PR29
Postby hyng » Fri Mar 15, 2013 11:15 am
hui WROTE:is it possible the PR29 act as standalone project by edit the code in mplab?
PR29 is a standalone project. Yes, you can do it by editing the sample code.
For door security, you may also refer to PR25.
Re: PR29
Postby hui » Sat Mar 16, 2013 9:31 pm
i had tried source code given by cytron. When i build it in mplab, it stated build failed. So what should i need to do to get build successful? i know cytron had provided the hex file but i want to try to build it in mplab by myself.
hui
Re: PR29
Postby robosang » Sat Mar 16, 2013 10:12 pm
what is the error oh....
Re: PR29
Postby hui » Sat Mar 16, 2013 11:23 pm
Clean: Deleted file "C:\Users\Desktop\1.mcs".
Clean: Done.
Executing: "C:\Program Files\PICC\Ccsc.exe" +FM "hardware psm\PR29 MPLABX\PR29 MPLABX\PR29.c" +DF +LN +T +A +M +Z +Y=9 +EA
BUILD FAILED: Sat Mar 16 23:20:44 2013
if use PIC C Compiler, got 5 errors.
hui
Re: PR29
Postby robosang » Sun Mar 17, 2013 8:29 am
It will be good if you can printscreen the output window of MPLAB IDE and share it here.
Re: PR29
Postby hui » Sun Mar 17, 2013 9:10 am
here the pic compiler
the mplab
hui
Return to DIY Project Set
