test 315Mhz Tx & Rx
test 315Mhz Tx & Rx
Postby geevan » Tue Mar 12, 2013 3:28 am
Hi, im using pic16f877a to connect with 315mhz Rx & Tx..can anyone help me by giving a simple coding to test this rf module when swicth(RB0) at Tx is pressed, LED(RB0) at Rx is blink..here i post my coding which is not work and i don't where is the mistake. Can anyone correct it. Thankz
TX
#include <htc.h>
#include "usart.h"
#include "delay.h"
__CONFIG(0x3F72);
unsigned char Data = 0;
void main()
   TRISB = 0x01;
   PORTB = 0x00;
   init_comms();
   Data = 0b10101010;
   while(1)
      if(RB0 == 1)
         putch(Data);
         RB1 = 1;
         DelayMs(200);
RX
#include <htc.h>
#include "usart.h"
#include "delay.h"
__CONFIG(0x3F72);
void main()
   TRISB = 0x00;
   PORTB = 0x00;
   init_comms();
   while(1)
      Data = getch();
      DelayMs(200);
      if(Data == 0b10101010)
         RB0 = 1;
geevan
Re: test 315Mhz Tx & Rx
Postby A380 » Tue Mar 12, 2013 11:28 am
Would you mind to show your schematics for TX and RX here?
A380
Postby geevan » Tue Mar 19, 2013 1:51 am
Rx and Tx schematic
RX
TX
geevan
Postby robosang » Tue Mar 19, 2013 9:46 am
What is the baud rate? what is the crystal value?
The circuit looks weird to me. Is there any power to microcontroller? If so why is 5V battery there?
Postby shahrul » Tue Mar 19, 2013 10:29 am
You must delete DelayMs(200); and putch(Data); continuously. Also use baudrate 1200.
Postby geevan » Tue Mar 19, 2013 1:39 pm
can you edit back my source code for tx and rx...because i dont know where should at the baudrate 1200
geevan
Postby geevan » Tue Mar 19, 2013 1:48 pm
my crystal value is 20Mhz...power supply for microcontroller is 5v as per schematic
geevan
Postby shahrul » Tue Mar 19, 2013 1:59 pm
geevan WROTE:can you edit back my source code for tx and rx...because i dont know where should at the baudrate 1200
For learning, you must do it yourself. Not my job to write a code for you.
Postby geevan » Tue Mar 19, 2013 2:19 pm
ok thanks...atleast can u tell me where sholud at the baudrate 1200
geevan
Postby robosang » Tue Mar 19, 2013 4:49 pm
at least? :mrgreen:
