Arduino Mega 2560 UART with SKPS
Postby Jonathan Law » Sun Mar 03, 2013 9:21 pm
I'm using Arduino Mega 2560, going to connect with SKPS using UART.
there are TX0,RX0,TX1,RX1,TX2,RX2,TX3,RX3
how will be the UART coding if i want to use TX0 and RX0 to connect with SKPS?
I found this in cytron tutorial but i'm not sure whether suit to my project or not.
unsigned char receive_data(void) //Function to wait for a byte receive from UART
  unsigned char temp;
  while(!Serial.available()); //Wait until data received
  temp=Serial.read();
  return temp;                    //Return the received data
unsigned char skps(unsigned char data) //Function to send out a byte via UART
  Serial.write(data); //Send new data
  return receive_data(); //Return received data
Jonathan Law
Re: Arduino Mega 2560 UART with SKPS
Postby yonghui » Tue Mar 05, 2013 1:04 pm
i think u just try and u will know whther it can be used or not.
Postby Jonathan Law » Tue Mar 05, 2013 11:59 pm
I connected PS2 wireless controller with SKPS and would like to establish communication between arduino mega 2560 with SKPS and PS2. Above code cnt working to establish this communication,anyone can help me in UART code??
Thanks
Jonathan Law
Postby robosang » Wed Mar 06, 2013 7:54 am
How is the connection? How do you know it is not working?
Postby Jonathan Law » Fri Mar 22, 2013 10:52 pm
I still having problem to work out with Arduino Mega 2560 with SKPS,
I had connect SKPS with 5V and GND from arduino board, SKPS TX pin and RX pin cross connect with Arduino Mega TX3 and RX3 pin
The connection I refer to http://tutorial.cytron.com.my/2012/07/16/interfacing-fd04a-and-skps-with-arduino/
SKPS STATUS led blinking while i press the PS2 controller, this mean SKPS received signal from PS2 controller but didt give me simple lights up led output. please refer my simple testing code below:
//skps protocol
#define p_Up       4
#define p_Right       5
#define p_Down       6
#define p_Left       7
#define   p_L2       8
#define   p_R2       9
#define p_L1       10
#define p_R1       11
#define p_Triangle  12
#define p_Circle    13
#define p_Cross       14
#define   p_Square    15
const int rx= 15;
const int tx= 14;
  Serial.begin(9600);      //Set serial baud rate as 9600
  Serial.flush();          //Waits for the transmission of outgoing serial data to complete.
  //Set the mode for each digital pins whether input or output
  pinMode(rx, INPUT);
  pinMode(tx, OUTPUT);
  pinMode(53,OUTPUT);
void loop ()
   if(skps(p_Up)==0)            //Check whether Up button is pressed
    digitalWrite(53,HIGH);
  else if(skps(p_Down)==0)   //Check whether Down button is pressed
    digitalWrite(53,LOW);
  unsigned char temp;
  temp=Serial.read();
I really need help ..
Jonathan Law
Postby robosang » Mon Mar 25, 2013 8:44 pm
I thought pin 14 and 15 is serial3 on Arduino Mega... did you study the page from Arduino.cc?
http://arduino.cc/en/Reference/serial
Postby shahrul » Mon Mar 25, 2013 9:14 pm
Jonathan Law WROTE:I still having problem to work out with Arduino Mega 2560 with SKPS,
Connection to TX3 and RX3, should use Serial3
Users browsing this forum: No registered users and 29 guests
