holeekao WROTE:Need help regarding powering 8 servos, I have a 6V output with 20A output power switching regulator. I recently burned 1 servo, because I thought that power switching regulator can regulate current supply to the load. So is it safe to connect all 8 servos to the power switching regulator?
gadgetng WROTE:holeekao WROTE:Need help regarding powering 8 servos, I have a 6V output with 20A output power switching regulator. I recently burned 1 servo, because I thought that power switching regulator can regulate current supply to the load. So is it safe to connect all 8 servos to the power switching regulator?
How is the servo burnt? It should be no problem with the power supply unless you connect the power in reverse polarity. Anyway, pls maake sure the power supply is really 6V.
Users browsing this forum: No registered users and 42 guests
