RTC - DS1307
RTC - DS1307
Postby khairul » Sat May 11, 2013 3:03 am
Assalamulaikum and Peace to all..
Currently i working on RTC project and have finish all the programming part n have tested it on PROTEUS simulation and it work well, the problem is when i Burn the program into PIC the output of the LCD is not as i expected... I thought it was the hardware problem
Circuit
1) 2 Pull up resistor : 10kOhm
2) Pin 3 is connected to 2 AA Battery : 3V
3) Basically i used Cytron DIY schematic...
khairul
Re: RTC - DS1307
Postby robosang » Mon May 13, 2013 9:28 pm
Show the real hardware.
Re: RTC - DS1307
Postby khairul » Tue May 14, 2013 1:58 am
Hai, i just want to inform you that i just found the problem, it just some silly mistake that the PCB routing is connected to the GND due to small soldering lid... but thanks for ur attention. :)
khairul
