LCD Can't work
LCD Can't work
Postby Enyuin » Tue Aug 13, 2013 10:49 am
I am using SK40C and I have downloaded the code from the cytron website to try the lcd code. But, it just can't work. BTW, I have changed the header file to p18f4550 instead of p18f4520 since i am using pic18f4550.
Enyuin
Re: LCD Can't work
Postby robosang » Tue Aug 13, 2013 11:44 am
Can the code works with PIC18F4550 with just header file change?
I don think that is the only thing you need to change, how about the configuration bits? That hold the oscillator configuration, without correct setting, not a single instruction can be executed.
Re: LCD Can't work
Postby Enyuin » Tue Aug 13, 2013 3:46 pm
Finally it works. The code is correct.The mistake i made is forget to put crystal on the circuit, that's why it can't display anything.
Thanks for the help though.
Enyuin
