Siemens TC35 development board setup
Re: Siemens TC35 development board setup
Postby kl84 » Wed May 28, 2014 5:47 pm
A photo of your board n connection will help.
kl84
Postby karthi06 » Wed May 28, 2014 8:13 pm
This is how my circuit looks like.
project circuit (3).rar
(33.32 KiB) Downloaded 113 times
karthi06
Postby karthi06 » Thu May 29, 2014 9:31 am
I measured the voltage at VCC at UART port and it shows 1.76V qhile plugged on to adapter.Is it suppose show like that ?
karthi06
Postby sich » Thu May 29, 2014 2:39 pm
Seems like you have attached uncommon file type. Possible to just show us jpeg file?
Postby karthi06 » Thu May 29, 2014 5:01 pm
Will this do ?
karthi06
Postby sich » Thu May 29, 2014 7:57 pm
You diagram shows that you are connecting the UART pins of your PIC to the DB9 connector on TC35 directly :!: Please refer to this diagram (for Ver2.0) as seen in TC35's user manual page 13.
Postby karthi06 » Fri May 30, 2014 1:15 am
That is for simulation purpose only.In hardware, i connected exactly as the manual has been written.
Thank you.
karthi06
Postby ober » Fri May 30, 2014 8:49 am
Please provide the actual hardware wiring picture. Most of people will say they follow exactly, but some time it is not the case.
Postby Manuel » Mon Jun 16, 2014 12:14 pm
Hey there! Greetings from Argentina.
Well, I have been having some troubles while setting up my development board, when I insert the SIM card, the board doeoes not recognize it, I mean the yellow lead doesn't stay off for 3 seconds like It's said in the user manual, so what I'm doing wrong? Is there a problem with my board?.
Thanks again, look forward to your reply! :D
Manuel
Postby ober » Mon Jun 16, 2014 9:07 pm
Do check if the SIM has credit and it is not PIN protected. It can be the SIM card holder is not clamping it firmly, do check that too.
PreviousNext
