I have this fsr-402. The detectable range for this sensor from datasheet is 1-100N, which mean the maximum can only reach 10kg. I am planning to use it to determine the ground reaction force from heel and some other researchers had used the same fsr to do the same thing.
However I failed to obtain the force above 10kg. Any solution for this?
