i need source code
i need source code
Postby zulpng3 » Tue Aug 19, 2014 12:22 pm
hello.can i get sample source code for flexiforce sensor.
zulpng3
Re: i need source code
Postby ober » Tue Aug 19, 2014 9:46 pm
You can check this great tutorial from bildr :http://bildr.org/2012/11/flexiforce-arduino/
Postby zulpng3 » Thu Aug 21, 2014 12:18 pm
can the force sensor operate without using arduino?
zulpng3
Postby yonghui » Sat Aug 23, 2014 12:26 pm
Any controller you like
Postby zulpng3 » Sun Aug 24, 2014 2:36 pm
i'm use this circuit.but MCP 6004 i replace it with LM358N integrate directly to microcontroller 16F877A. can you help me the sample source code without using arduino?
zulpng3
Postby yonghui » Mon Aug 25, 2014 10:51 am
before u starting writing code. its better u setup the flexi force and opamp to see the output signal is working fine. see under osciloscope. reminder MCP6004 maximum working voltage should be 5V not to exceed.
Postby zulpng3 » Tue Sep 02, 2014 4:53 am
hello,
i already done the circuit using LM358N and output voltage is abou 3.7 V.can you help me the sample source code without using arduino
zulpng3
Postby yonghui » Wed Sep 03, 2014 12:01 am
Without Arduino... Then what is the controller u are going to use? The output voltage will change when u press the sensor?
Postby zulpng3 » Wed Sep 03, 2014 11:11 pm
i'm using microcontroller 16F877A. when i press the force sensor output voltage i obtain is below 5V.
zulpng3
Postby larzazral » Thu Sep 04, 2014 8:19 am
larzazral
